I'm designing a floor truss system that has a short cantilever (1'6") that is perpendicular to the trusses. Generally I follow the 150% rule of thumb which would give a 4'6" back span, which will end up being 5'4" to keep the 16"oc truss spacing nice and neat. The question I have is, can you reduce the required backspan when using a truss instead of a joist? Its going to be hung from a girder truss. The cantilever is supporting a doorway/entry and a gable truss with 2' OH.
It got me thinking because of how jack trusses are often designed. Very normal to have a 2'+ overhang or cantilever with only a 2' span back to the girder truss.
EDIT: Should also mention truss depth is also 1'6".
