LearnerL
- Mar 12, 2003
- 2
When you design a cantilever steel beam with moment connections at both sides of the column, do you assume part of the moment goes to the column (due to relative stiffness of the beam and the column) and design the column for that additional moment?? Please advise. For some reasons, we have been assuming the beams are having two pinned connections, and designed columns with vertical load only. Now, I am worried...
