"I'd guess it would take me a couple of hours."
Which leads me back to my original question? Why? Looking at the image of the structure I figure I could build this FEA model and have many frequencies and mode shapes in less than five minutes. As engineers we often need to balance accuracy against budget and schedule. I would certainly question spending 5 minutes to do an FEA model and then 2 hours of hand calculations to verify it. On the flip side, I would question doing an FEA model of something I could easily figure out within five minutes using a hand calculation. In my mind at least, FEA is not for solving the easily solvable, but for coming up with approximate numerical solutions to highly complex problems that can't be solved easily (or at all) by other means.
In situations similar to this there are a couple of things I might do. Easiest thing you could do is perform a mesh refinement study. Run the model again and again with smaller and smaller elements. If your model is adequately meshed you will see little change in your results between successive iterations. In some cases I might say that I know my results should be between two extremes, so I run the extreme cases to come up with lower and upper bounds on my problem. My results should fall somewhere between the bounds. Another idea along these lines would be to come up with a very simplified and easily solvable model that will give you an idea if you are in the ballpark with your results.
