Cant find Task Pane
Kathie
Hello All,
My Task Pane in 2005 is no longer visible even if I go under "view", and check "task pane".
Anyone else have this problem and know where else to find it - or at least the toolbox.
Thanks in advance
HKEY_CURRENT_USER\Software\SolidWorks\SolidWorks 2005\User Interface\Toolbars
Go to Start, Run, and typoe regedit. Rename the above key in your registry with Solidworks shutdown. Then restart Solidworks, your Task Pane should come back. This basically removes your toolbar setting and they go back to the default. Recently had this happen to me and the above fix worked out great.
Jim
