Hi guys
Iwould like to know whether Variable speed drives can be used in motors that drive Slurry pumps. Also I would like to know the following details.
1. Can VSD controlled motors develop sufficient torque to clear chocked delivery lines.
2. Is it advisable to install a VSD for above said duty. Please comment from both operational and econimical point of view
3. Can a VSD automatically increase the RPM of motor based on the torque load devloped by the pump. If not is there any other equipment available in market
Eqpn Details:
VSD we are having : SIEMENS Midimaster 37 KW
Motor : SIEMENS 50 HP 3P 50HZ
Pump : 4/3 WARMAN Slurry pump
Duty : Sand Slurry (Load varries from 35 tph to 50 tph (Dry Solids)
Present Loading : 40 Amps at 2100 pump RPM (50 tph solids)
Iam just new to your forum and so please dont mind if the same question was already asked by some one else.
Eqpn Details:
