Can someone tell me the safety issue
steveTme
Chemical
Apr 2, 2014
Can someone tell me the safety issue if there is a missing bolt on the flame arrestor of a glycol dehy? I have included a pic.
Much appreciated.
Ate they missing, or are they broken?
Missing, isn't a problem, broken off threaded studs one wonders why, and would warrant investigation.
Eric
API 510 & 653
Think there are two missing.
They look rather weedy bolts so clearly this isn't under significant pressure but impossible without a drawing to see why this plate should be connected and what it is covering.
The "Safety Issue" of missing bolts may not be the biggest threat to your operation.
If there is an accident involving this component (or even any nearby component) lawyers and legal assistants will descend on the site and look for any evidence of poor maintenance. Even if there is no evidence that the missing bolts caused a problem, cold blooded attorneys will point the missing bolt holes as "bona-fide evidence of the lack of competent maintenance"
Bolts are cheap ....
MJCronin
Sr. Process Engineer
