Hi all,
Before I begin, I am new to this forum so if I am conveying my question incorrectly, please bear with me. I have been trying to acquire Solidworks Simulation for the past 3 months (I’m still awaiting my purchasing department), and I only have another 3 months left in my rotation assignment, so any knowledge I can obtain to help me get started the moment I get the program would help tremendously.
I am trying determining the change in resistivity due to a bad electrical connection [the interface of the connector is improperly crimped] on a cable joint.
1 2 3 4 5
1= Cable 1
2= crimped connector 1
3= yoke
4= crimped connector 2
5= cable 2
Given:
What I know is the power generated [I^2*R] by the conductors inside of both cable 1 and cable 2, as well as the surface temperatures of everything. Knowing the material of the cable, I’ve been able to determine the temperature of the cable conductor [by setting the total Q from heat transfer (conduction convection and radiation) to the environment equal to the power generated from I^2*R losses] I also know that the bad crimp had caused a severe increase in temperature in both connectors and yoke.
What I don’t know is the power generation, resistance, or temperature of the connector conductor [its 13kV, everything is insulated]. My question is: knowing the current, can Simulation be able to determine the power generation despite not knowing the resistance? Normally it would all be the same as generated in the cable, but it is altered in this case due to the increased resistance associated with the connection. From what I know, (sorry, I’m Mech E, not EE) I’d need one to determine the other. If I put them back into the heat transfer eq from above, I’ll have three unknowns, the third being the temp of the connector, so that still won’t help. Do any of you know if simulation would be able to find a way around this? If so, do you know how?
1 2 3 4 5
1= Cable 1
3= yoke
5= cable 2
Given:
