One caveat, sugaring can be detected if the groove weld is not too thick. I assume that the welds are not socket welds.
If groove welds and the welds were was made with the manual GTAW process, you should expect that sugaring has occurred which could be highly detrimental with regard to corrosion in the service environment.
