bdn2004
- Jan 27, 2007
- 799
I'm looking at this engineering package calling out line reactors on the incoming line to each of the new VFDs that will drive a pump.
It's obvious they picked the size of the line reactor from a chart. But how was this value actually determined? And if these are so common why doesn't the VFD manufacturer just build them into the units?
Is there anything that can be screwed up by using these? I don't like to be doing something - just because.
Also, I don't see any special protection for these. They will be operating at 480V. They don't have a finger safe design. Shouldn't they be encased? And as like with CT's that require special shorting terminals, why is that not required on the line reactors?
