KyleWilcox
- Aug 10, 2006
- 31
Hi there -- is it possible to alter any of the hole wizard "Type" settings per config? I was hoping to fill out a design table with different NPT diams and have the wizard feature generate the NPT geometry, but seems like the hole wizard doesn't want to put itself into the design table, and for that matter it can't even be changed manually between configs... I'm wondering if I'll have to just do it with a regular cut.
I'm also wondering if there's a list of all the generic parameter names for each feature, like D1 in an extrude is the extrustion distance, D2 in a pattern does what, etc... anyone know?
Thanks for any input!
