Can anyone help me in setting up a image blueprint in pro-e
ask4selvakumar
Aerospace
Jun 27, 2007
I am trying for a long time to set up a image into pro-e wildfire and 2001. can anyone tell me if it is possible and supported in pro-e as in rhino3d and maya
Create 3 surfaces (same as the 3 defeult datums) and then put the images on these planes. Go to the advanced feature when you assihn a color and click on map button of the texture box.
-Hora
If you have Wildfire, you can also use the Style feature. It contains a sub-feature called Trace Sketch. Wildfire 1 only allowed you to put it on the default datum planes, but WF2 allows you to place trace sketch images on any plane.
Trace Sketch was not an option in 2001, I believe.
JKG,
TraceSketch - there is not such option in Pro2001.
-Hora
