Dec 22, 2009 #1 ME7 Mechanical Joined Oct 11, 2003 Messages 28 Location US Hi, I am working a new project that involves deformation of glass from given loads on the order of 0.1 to 1 nanometer. Does Ansys or Cosmos have the capability to capture this level of resolution? Thank you for the help!
Dec 26, 2009 #2 Stringmaker Mechanical Joined Mar 18, 2005 Messages 513 Location US Ansys most certainly does. However, you should consider the units which you use in constructing and post-processing the model if this is the case. Also, ensure you are using a double-precision solver. -Brian Upvote 0 Downvote
