The diaphragm has separated from the stem inside a weir type diaphragm valve in vacuum service.
The process vacuum is holding the diaphragm in the closed position, which appears to be intact because it is not passing.
If the bonnet was drilled and tapped for a fitting and attached to a vacuum pump, it should open if the vacuum imposed is greater than the process vacuum.
Will lifting the diaphragm by removing air pressure from the bonnet impose more or less stress on the diaphragm than 'normal' operation of the stem?
If it does, should the diaphragm deflection be controlled by 'feeling' when the stem is contacted by the rising diaphragm?
