Camshafts -Carbureted vs Fuel Injected
cirque
Automotive
Does anyone know the difference in theories between a fuel injected camshaft and carbureted camshaft?
I am putting Dual Weber sidedrafts on a SOHC VTEC Honda. I was told that the stock fuel injected camshaft will not be optimal for this setup. Any help is greatly appreciated.
If the inlet opens to soon, you get reversion of flow in the inlet tract and out the carby or fuel injection runners. On a carby, this reversion through the venturi causes a double or triple charge of fuel into this air. On an efi engine, the a/f ratio is uneffected by reversion.
Bottom line is on a carby engine, they run rich until the inertia in the column of air is enough to overcome reversion, where an efi car will retain good a/f ratio at lower speed.
The earlier the inlet valve opens, the more the reversion
pat
Pat's correct, also without the oxygen sensor you can run more duration and closer valve seperation angle (that would be putting to much unburnt fuel in the exhaust at low rpm for the oxygen sensor to monitor correctly) that will really make some more mid/top end power.
cheers
jeremy
