N
nikolaeff
Guest
Hi! Our machine is with A and C rotary tables. A-axis is reversed and has limits from -25 to 95 degrees. C-without limits. The right code is:
A0 C0
A90.
C180.
A0 C0
....Y-20.
the postprocessor outputs:
A0 C0
A90.
C180.
A0 C180.
....Y20.
From 5d machining panel:
-with linearisation enabled for rapid-no change
-with linearisation enabled for feed-no change
-with both:
A0 C0
A90.
A270. outside limits
A0 C0
....Y-20.
How to use ppcommands: LINTOL/ON,ROTREF,WIND and where to put them. Do I need some special macro to prevent the travel in the limit zone?
Campost v17
Thanks!
A0 C0
A90.
C180.
A0 C0
....Y-20.
A0 C0
A90.
C180.
A0 C180.
....Y20.
-with both:
A0 C0
A90.
A0 C0
....Y-20.
Campost v17
Thanks!
