Is it feasible to generate a 5% camber (height of curve vs length, ie 100" length and 5" height) in a 3" Sq 1/8" wall 6061-T6 aluminum tube, by welding beads along the side inside the camber? The idea is, the welds would distort the tube into an acceptable curve. This is proposed to make a mild large radius curve without heavy machinery. I have no idea if such a thing would work. Residual stresses may be an issue, since the welded side will be in tension.
Any thoughts or ideas would be appreciated.
