CAM : NXMessageBox.Show
UserCFAO
FR
hello ,
i would like to put all operation name in a message box
Can you help me ?
Code:
Code:
 Dim theSession As Session = Session.GetSession()
        Dim theUISession As UI = UI.GetUI
        Dim response As Integer
        Dim operationName(1) As String = ""
        operationName(0) = ""
 theUISession.NXMessageBox.Show("Question", NXMessageBox.DialogType.Question, operationName)]
I don't currently have access to a CAM license to test this, but I think it will do what you want.
Code:
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Imports NXOpen.CAM
Module Module2
    Sub Main(ByVal args As String())
        Dim theUI As UI = UI.GetUI()
        Dim dispPart As Part = theSession.Parts.Display
        Dim lw As ListingWindow = theSession.ListingWindow
        lw.Open()
        Dim operationNames As New List(Of String)
        Dim opers As OperationCollection = dispPart.CAMSetup.CAMOperationCollection
        For Each oper As Operation In opers
            operationNames.Add(oper.Name)
        Next
        theUI.NXMessageBox.Show("Operation names", NXMessageBox.DialogType.Information, operationNames.ToArray)
    End Sub
End Module
www.nxjournaling.com
@cowski - I just tested it - works like a charm :*)
Mark Rief
NX CAM Customer Success
Siemens PLM Software
thanks @cowski it works great ! [thumbsup2]
A another question :
How you do , for just display the selection operation name and not all operations name ?
Untested code:
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.CAM
Module Module3
        Dim theUfSession As UFSession = UFSession.GetUFSession
        lw.Open()
        Dim setupTag As Tag = Tag.Null
        theUfSession.Cam.InitSession()
        theUfSession.Setup.AskSetup(setupTag)
        If setupTag = Tag.Null Then
            lw.WriteLine("no CAM setup, journal exiting")
            Return
        End If
        Dim selectedCount As Integer
        Dim selectedTags() As Tag
        ' Get the selected nodes from the Operation Navigator
        theUfSession.UiOnt.AskSelectedNodes(selectedCount, selectedTags)
        If selectedCount = 0 Then
            theUI.NXMessageBox.Show("Selected Operations", NXMessageBox.DialogType.Information, "No operations were selected")
            Return
        End If
        For Each tempTag As Tag In selectedTags
            Dim tempOp As Operation
            Try
                tempOp = Utilities.NXObjectManager.Get(tempTag)
                operationNames.Add(tempOp.Name)
            Catch ex As NXException
                'not an operation
            End Try
        Next
        If operationNames.Count = 0 Then
        Else
            theUI.NXMessageBox.Show("Selected Operations", NXMessageBox.DialogType.Information, operationNames.ToArray)
        End If
    End Sub
End Module
that's exactly what I want , thanks for the support
