I am trying to calculate the effect of filling a steel pipe pile with concrete to control deflection due to "lateral load". The concept, which I am following, is to calculate the equivalent steel pipe pile section that represents the composite section.
I reviewed the post, which has discussed the process of this calculation at:
According to the post, the equivalent section can be calculated based on the transposed moment of inertia as:
I(transposed) = I(pipe) + I(concrete)*Ec/Es
I use the “I (transposed)” to back calculate the pipe wall thickness by fixing the diameter then calculate the deflection.
My question is how different if I use similar concept based on "Area" instead as the followingin:
A(transposed) = A(pipe) + A(concrete)*Ec/Es
The equivalent area will be used to back calculate the wall thickness as above.
Which formula is the right for the purpose since both will give different results?
I realize the inertia uses the diameter to the fourth power compared to the area that uses the diameter squared, which is clear. However, which method is right?
