I have a situation that requires expertize beyond my capabilities. I need to know how to calculate the individual tensions in each strand and then find the bearing loads. the setup is that I have two wheels one driven the other free, each with ten grooves (with an included angle of 45 degrees), the strand (1/2" dia) first enters the driven wheel, (under 540 lbs of tension) makes a 180 degree wrap and then enters the free wheel (see the attached file) makes a 180 degrees wrap and enters the 2nd groove of the driven makes a 180 degree wrap a then enters the 2nd groove of the free wheel. this continues until the strand leaves the 5th groove of the free wheel under tension of 18,000 lbs wraps around the turn a round wheel (wheel is free) 180 degrees and the enters the 6th groove of the free wheel. it then makes successive 180 degrees wraps of the driven and free wheel until it leaves the driven wheel at 540 lbs of tension. I would greatly appreciate any help in solving this problem.
