This makes sense now for the tension on the lowest grid:
(a) if you assume zero friction at the base between the reinforced soil and the foundation soil, the entire reinforced soil zone would be assumed to move under active pressure without friction; thus the tributary area for tension in the grid and against the block would go fully down to the foundation level and 1/2 way up to the overlying layers.
(b) if you assume friction at the base, the very lowest level of reinforced soil would be assumed to have frictional resistance from the foundation soil; thus the tributary area for tension in the grid and against the block would go only 1/2 way down to the foundation level and 1/2 way up to the overlying layers.
option (a) is conservative, especially if you were not certain how the wall would behave, but if there was friction between the reinforced soil and the foundation soil then option (b) would be more likely.
Thanks. I get it now.
