fastline12
Aerospace
- Jan 27, 2011
- 306
A bit outside my area of work but I am mostly trying to understand some concepts. It seems most dehumidifiers rate performance in volume/time, not BTUs, watts, etc. Air conditioners are rated with BTUs cooling with no regard to air moisture.
I realize and have no problem calculating the dew point based on air temp, RH, pressure, etc. I also realize that simply passing air across an evap that has a surface temp below the dew point will condense the moisture. However, I have never been able to quantify the effects of an air conditioner in regards to separation of air cooling and water condensing.
What am I missing? Or am I simply over thinking this? I might need to dust off the thermo book...
