markarnold
I am reviewing specifications of an older pinion gear design where changes to the specifications were not complete. The measurement over pins was changed to modify the backlash between the pinion and its mating rack. My problem is I need to update the amount of rack movement for a given rotation of the pinion gear. Of course, I then need to know the updated pitch diameter. There are five sizes of gears of which I need to determine the pitch diameter. I have not found a way to translate the measurement over pins into the pitch diameter. The gears are 20° pressure angle spur gears. Any help is appreciated.
