shoehorn6
- Sep 14, 2011
- 4
Right I have been thrown in at the deep end with weld calcs. Previously I have never dealt with them so could do with some help.
I am trying to calculate if my fillet weld is going to be strong enough.
I have a circular 6mm plate, diameter =144mm that is going to be weld inside a pipe. It will be welded at 3 tabs each 10mm in length.
At present I am using a 4mm double sided fillet weld and need to check if this will be strong enough.
There will be pressure of 5.4bar in the pipe.
The length of pipe is 200mm
Let me know if you need anything else.
Your help would be greatly appreciated.
Cheers
Cheers
