Calculate Pipeline Pressure decay
zane009
Chemical
AU
I am needing to calculate the pressure decay of a liquid ammonia pipeline (-33 oC). I am wanting to calculate the decrease in line pressure and discharge flowrate from a leak in the pipeline. This it to represent how much material is release after the isolation valve system is activated.
Thanks for any assistance
Type "Leak" in the above left search box and look at page 2
"Pumping systems account for nearly 20% of the world’s energy used by electric motors and 25% to 50% of the total electrical energy usage in certain industrial facilities." - DOE statistic (Note: Make that 99.99% for pipeline companies)
The pressure decay will be a fuction of ground temperature and heat transfer. The -33 C is the tempearture with 1 atm on the line, which means it won't come out. But, as the line gains heat from the ground, it will boil and the vapours will be released.
