Are you interested in 3D Modeling in AutoCAD ? Assembly 3D Modeling in AutoCAD ? As an Inventor user, I can ASSURE YOU that 3D Modeling in AutoCAD is NOT ONLY DOABLE, but appropriate and PRACTICAL as well.
If they're searchable, look for my previous posts (very historic but absolutely pertinent) on this topic.
First, MASTER the COMMANDS. No substitute for KNOWING what you are doing, all "I hate AutoCAD 3D " posts notwithstanding.
Second, develop APPROPRIATE Techniques.
Third, construct your own operating menu with your favorite commands. THIS will take awhile as you develop your technique, but will ultimately make all the difference.
Hint: For those of you using previous versions of AutoCAD, research SOLDRAW (NOT NOT NOT SOLPROF ). Its FAR superior to ANY FLAVOR of Flatshot, and absolutely reliable. CLUE: LEARN IT and what it takes to set it up and use it (there are ONLY 3 commands, they work together, and complement each other PERFECTLY) .
In r-2012 there was a command to auto-generate the primary AND projected views (ala Inventor) negating the need for SOLVIEW/SOLDRAW. IF you have that version or 2013 which promised significant improvements, you will love it as a replacement for about 80+% of SOLVIEW/SOLDRAW, but later versions may have obviated both. I've been on Inventor since, (along with some other packages) so others with more current ACAD exposure may have some direction to offer on this point, so CONTINUE in your journey, and FOCUS on SUCCESS !
PAPERSPACE will be a HHUUGGEE advantage, if you're willing to learn it and use it.
TRICK: After you've made your COMPONENT or ASSEMBLY MODEL in MODELSPACE, and AFTER you've set up your PAPER-SPACE drawing sheet TABs, add another TAB at the end. Make ONE Viewport but DO NOT ZOOM-LOCK IT. When later in previous Paper-Space tab Viewports you extract the needed 2D view (even the 2D ISOMETRIC VIEW of the part for the ISO pic of the part on the part cover page, usually sheet-1) using SOLDRAW (NOT NOT NOT SOLPROF) you can set the viewport to NOT show elements created in previous viewports (HINT: Its a single click in the LAYERS command - LEARN YOUR TOOL !) meaning that the confusion that 3D'ing in MODELSPACE creates is COMPLETELY OBVIATED. This will give you an ABSOLUTELY CLEAN operating window, leading to 3D MODELING SUCCESS in AutoCAD.
LEARN DISPLAY MODES and how they work. This will be HUGE for you !
No, there is ABSOLUTELY NOTHING WRONG with 3D Modeling in AUTOCAD - YOU just have to LEARN YOUR TOOL. THIS is why SO MANY companies are realizing that their investment in AutoCAD can meet 90+% of their 2D AND 3D needs, and are ADVERTISING JOBS if YOU know what you're doing ! CASE HISTORY example: I was able to MODEL 3 DIFFERENT iterations of a HIGHLY DETAILED Subsea installation using AUTOCAD 3D in the same time our FASTEST Inventor user was able set up his first one. He was so focused on setting up all of the automated features that with BLOCKING and GROUPING I was able to set up NOT ONLY the 3 Assembled systems, but alternate positioning FOR EACH, as well. We then moved to Inventor to do the formal system model. I was the Lead Designer on the project (Foster-Wheeler/Cameron), and while we delivered ON TIME (NOT ahead of schedule, darnit!) but also were able to come slightly under budget. WHY ? because we were able to EFFECTIVELY USE THE TOOLS at our disposal to evaluate options and PROCEED ACCORDINGLY.
Best of luck to you and to ALL who seek to PROGRESS in these iffy times !
-C.
