The pressure drop of a fluid through straight pipe or through a fitting is proportional to [ρ]v
2. Velocities for gases are typically around 10x that for liquids, so the v
2 term increases the pressure drop by about 100, but because your density is roughly 1000th of that for a typical liquid the net effect of [ρ]v
2 is to decrease typical pressure drops by a factor of around 10.
If you are working with a 3" pipe then 1 m/s water flow will give you a pressure drop of about 0.6 psi/100ft (apologies for mixed units). In the same 3" pipe if you have your gas with a density of about 0.8 kg/m
3 and a velocity of 10 m/s then the pressure drop will be about 0.06 psi/100 ft. Again, a factor of 10x less.
So, although it is true that the pressure drop for gases through pipe fittings is generally much less than for liquids it is equally true that generally the pressure drop through the straight pipe is also much less for gases. As it turns out (in my carefully selected example) the pressure drops through straight pipe and through fittings decrease by the same factor when moving from liquids to gases. This makes the minor losses through the fittings, relative to the pressure drop through the pipe, roughly the same for gases and for liquids.
Depending on your application, it may not be realistic to automatically disregard the pressure drop through the fittings for gases. [Start David harassing mode] You could get into bad habits if you do not tackle these problems with the proper rigorous tools every time. [/End David harassing mode]
Katmar Software - AioFlo Pipe Hydraulics
"An undefined problem has an infinite number of solutions"
