MartinSweden
- Mar 23, 2009
- 20
Hi!
I'm working on a project with electrical cables that is to be bundled together with cable strips.
The cable strips has a diameter range of let's say 3,5mm to 45 mm that the strip can bundle together.
My question is if it's possible to use Deformable Parts to change the diameter of the cable strip without the addition of references for sketch planes etc.
I have added the diameter expression (p22) in Create Def. Part. and determine the range in which the diamter is allowed to be altered.
However I don't seem to reach the goal were I add the cable strip to an assembly and for each instance is able to have an specific diameter.
Se attached file if the text don't make sense.. ;-)
