duncan8943
Chemical
- Feb 9, 2010
- 11
I have an existing PSV on a butane bullet which is set at 250 PSIG. The PSV is too small for fire sizing. I have two choices: (1) Replace the PSV with a larger one or (2) Add an additional rupture disk to give the required relief rate. The vessel MAWP is 300 PSIG. I am thinking about installing a 300 PSIG rupture disk on the vessel. With fire sizing, I have thought about incidents where the metal weakens and the vessel explodes. A rupture disk would prevent this. How many of you do the above or protect your bullets with rupture disks? Any other ideas or comments are greatly appreciated. Thanks.
