I'm working on the design of a buried hydrogen pipeline (API-5L X60) that is several miles long. I'm using Caesar II software to evaluate it and have access to ASME B31.1, B31.3, and B31.12. I'm assuming an ambient temperature of 70F (should probably consider using 50F) and the design temperature is set at 180F. I first wanted to see if modeling the pipe as direct buried would have any issues. The results are failure in the sustained and expansion cases and extremely high forces at certain elbows, upwards of 700,000 lbs. Failing in the sustained case may be a separate issue. I followed the process in ASME B31.12 to determine the wall thickness but maybe a thicker wall is required. I have a few questions: 1) Is there an industry accepted practice for reducing the design temperature based on the distance from the source? 2) Is there a good way to determine if the pipe will slip or if soil will hold it in place and not allow it to slide? This could make the difference between a pipeline that is pretty much a straight shot compared to dozens or even hundreds of expansion loops. Any input to these questions or just general insight would be greatly appreciated.
