Hi All,
Detailing a job right now with W18x35 and W16x36 with cap channel C8x11.5. Some bays have vertical bracing ranging from 45 to 20 kips and I was wondering if the C8x11.5 cap channels should be notch to allow the brace gusset plate to be welded directly to beam top flange ends or weld the gusset plate to C8 and weld continuous the channel ends for the length of the gusset plates.
Thanks in advance.
Thanks in advance.
