dftengineering
I am building a simple flow loop to test flow capacity (water) thru valves. Is there a "building flow loops for dummies" book available? Is there a way to calibrate the system (flowmeter, pipes, pressure transducers) to ensure accuracy?
Specifically, I am having trouble getting the pressure transducers tuned in on the data acquisition system. There is way too much flutter or bounce in the pressure readings. How do I dampen the response of the transducers?
