Recently I had a couple of projects that involved lifting rings [that were part of equipment] and a couple of arches that were loaded with both in-plane and out-of-plane forces. (By in-plane, I mean forces that are applied radially to an arch or something like a vertical load that can cause snap through buckling. By out-of-plane forces I mean forces coming in from a perpendicular direction to that…..something like wind load.)
I pulled all available resources off my shelf……but was still left with a very important question: almost all the formulas that dealt with arch/ring buckling typically gave buckling values that we caused by in-plane forces. I really couldn’t find anything for out-of-plane loads. Now, one reference I have [i.e. ‘Guide to Stability Design Criteria for Metal Structures’ by: B.G. Johnson, 3rd Edition, p.476-477] had this to say on the subject: “Out-of-plane buckling of rings, arches, and other curved planar members is in every way analogous to lateral-torsional buckling [LTB] of beams and beam-columns.” They proceed to give a number of buckling formulas, but I’m not sure they are applicable to the out-of-plane forces I discuss here.
So I guess what my question is: where can you find allowable for such a situation? Is it just a matter of calculating LTB as per an applicable code? If so, what would you call your unbraced length? For example, in that ring lift scenario I mentioned earlier, we just basically lifted a ring with attached lugs (8 of them around the circumference; it had a 30’ radius). The self-weight of the ring is causing the out-of-plane moment. Obviously the lifting point isn’t restrained torsionally…….but laterally, I would think the arch [think of the ring in pieces] would be stiff enough to prevent lateral translation (but obviously that would require calcs). [What I did there for unbraced length was subdivide the circumference of the ring into 4 pieces; because I reasoned that it would buckle into at least 4 parts.] Same deal with an circular arch (receiving out-of -plane load): at the least, I would think the highest unbraced length would be ¼ of the circumference (if it was a complete circle). Only thing about those approaches is: you kind of counting on the structure to brace itself…..and I always thought that was big no-no.
Anyway, any insight is appreciated…..and be sure to have a good 4th.
