I'm a summer intern and I'm working on electrical energy conervation. One area I would like to improve electrical usage in would be the air conditioners. Here at the plant, we use chiller systems and package units for some buildings. With the little bit of thermo that i have had so far, I managed to calculate the amount of power needed to heat a certain volume of air from 45 degrees to X degree in the chiller unit. I used Air density = 1.29 kg/m3; Cp = 1000W/kg-K ; and substituted K with C b/c it would be the change in T anyways. The only part im missing is the time it will take for it to actually heat this volume to the temperature. How is that calculated? Also, does the BTU listed on AC units represent the amount of energy needed to raise the room size range 1 degree?
With the package units that operate just like your conventional home unit, does the BTU represent the same as the above question? Also, how would i go above calculating how long it will take for a volume to cool to specified temeprature?
This would be very help for my project. Thanks Alot
