BS EN 13480-3 equivalent for ASME B31.3 - Stress Intensification factors
NimChimpsky
GB
Hello All,
Does anyone have experience with BS EN 13480 Metallic Industrial Piping? I'm trying to find the equivalent section to ASME B31.3 Appendix D that deals with stress intensification factors for elbows and pipe bends.
Also, I can't seem to find any section in BS EN 13480-3 or BS EN 13480-4 on external loads applied to the pipe work to validate the strength of the welds for a simple pipe run. Can anyone point me in the correct direction?
Any help you can offer would be gratefully appreciated.
Thanks.
I am Italian : as far as I know steel pressure pipes are manufactured according to AWWA C200, fittings according to AWWA C208 and calculations performed according to AWWA Manual M11.
For Your info I attached here detailed calculation sequence for elbow
 http://files.engineering.com/getfile.aspx?folder=d1537c1a-9a36-41d4-a32b-a87e8afb83ed&file=AWWA_C208_elbow_en.doc
I believe EN 13480 uses the same apporach as B31.3 in that (butt) welds are equivalently strong as run pipe. SIF's are used to determine the stress concentration factors, rather than stresses in weld.
SIF's are found in para. 12.2.7.4 annex H
Also try to review annex Q, for simplified stress analysis. Though this chapter is not as straight forward as you might think, it can be good practice.
RobyengIT - Thanks for the documents, I've reviewed them both and I think the example calculation will be a useful reference in future calculations.
XL83NL - Thank you for the direction in regards to stress factors. I will review and post on my progress.
Thanks again
