The parameter 'e' from Brom's method, is usually described as the 'height of lateral load above grade'
So, if I have a billboard, and the resultant of the wind forces are at the center of that billboard, will 'e' then be the distance from the center of the billboard to grade? Or is it from the top of the pile/underside of baseplate to grade? Thank you!
