Broken Links
vegetagaru
Computer
Jan 14, 2015
134
so i have bits of code that i found somewhere on web (if anyone knows the code please post the source)
The Journal its suposed to look for broken links and report the assembly that contains the bronken link aswell as the parent feature and to who assembly links belong.
somehow its not working in some links (image attached)
its not a broken link ?
CODE:
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Assemblies
Module NXJournal
    Public theSession As Session = Session.GetSession()
    Public ufs As UFSession = UFSession.GetUFSession()
    Public lw As ListingWindow = theSession.ListingWindow
    Dim theUfSession As UFSession = UFSession.GetUFSession
    Dim sourceTag As Tag
    Dim linkBroken As Boolean = True
    Dim workPart As Part = theSession.Parts.Work
    Dim dispPart As Part = theSession.Parts.Display
    Sub Main()
    lw.Open
    Try
        Dim c As ComponentAssembly = dispPart.ComponentAssembly
	if not IsNothing(c.RootComponent) then
            ReportComponentChildren(c.RootComponent, 0)
        else
            lw.WriteLine("Part has no components")
        end if
    Catch e As Exception
        theSession.ListingWindow.WriteLine("Failed: " & e.ToString)
    End Try
	lw.WriteLine("FIM")
    lw.Close
    End Sub
    Sub reportComponentChildren( ByVal comp As Component, _
        ByVal indent As Integer)
        For Each child As Component In comp.GetChildren()
	    If LoadComponent(child) Then
'		lw.WriteLine("file name: " & child.name)
'		lw.WriteLine("  ")
	Dim MyPart As Part = child.Prototype.OwningPart
	Dim sourceTag As string
	Dim Partname as string
	   For Each theFeature as Features.Feature In MyPart.Features
            If theFeature.FeatureType.Contains("LINKED") Then
               theUfSession.Wave.IsLinkBroken(theFeature.Tag, linkBroken)
                If linkBroken Then
			theUfSession.Wave.AskbrokenLinkSourcepart(theFeature.Tag, Partname, sourceTag)
		lw.WriteLine("  " & theFeature.GetFeatureName)
		lw.WriteLine("		parent file: " & Partname)
		lw.WriteLine("  ")
		end if
           End If
        Next
               Else
                'component could not be loaded
            End If
            reportComponentChildren(child, indent + 1)
        Next
    End Sub
    Private Function LoadComponent(ByVal theComponent As Component) As Boolean
        Dim thePart As Part = theComponent.Prototype.OwningPart
        Dim partName As String = ""
        Dim refsetName As String = ""
        Dim instanceName As String = ""
        Dim origin(2) As Double
        Dim csysMatrix(8) As Double
        Dim transform(3, 3) As Double
        Try
            If thePart.IsFullyLoaded Then
                'component is fully loaded
            Else
                'component is partially loaded
				lw.WriteLine("Componentes nao carregado completamente: " & Partname)
            End If
            Return True
        Catch ex As NullReferenceException
            'component is not loaded
            Try
                ufs.Assem.AskComponentData(theComponent.Tag, partName, refsetName, instanceName, origin, csysMatrix, transform)
                Dim theLoadStatus As PartLoadStatus
                theSession.Parts.Open(partName, theLoadStatus)
                If theLoadStatus.NumberUnloadedParts > 0 Then
                    Dim allReadOnly As Boolean = True
                    For i As Integer = 0 To theLoadStatus.NumberUnloadedParts - 1
                        If theLoadStatus.GetStatus(i) = 641058 Then
                            'read-only warning, file loaded ok
                        Else
                            '641044: file not found
                            lw.WriteLine("file not found")
                            allReadOnly = False
                        End If
                    Next
                    If allReadOnly Then
                        Return True
                    Else
                        'warnings other than read-only...
                        Return False
                    End If
                Else
                    Return True
                End If
            Catch ex2 As NXException
                lw.WriteLine("error: " & ex2.Message)
                Return False
            End Try
        Catch ex As NXException
            'unexpected error
            lw.WriteLine("error: " & ex.Message)
            Return False
        End Try
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        Return Session.LibraryUnloadOption.Immediately
    End Function
End Module
NX8.5 - NX9 User
 http://files.engineering.com/getfile.aspx?folder=35df17a2-8418-494b-bd81-e4bd2b16f819&file=broken_Link.jpg
The link that you show technically isn't broken; a broken link would show a broken chain icon (see below).
download.aspx
Perhaps your link specifies more than one body, but one of the bodies is missing. If the other body(ies) update, then the link is not considered broken, but it is missing a reference.
The code that you posted looks like it is *mostly* mine from an early version of finding wave links in parts. The latest (published) version can be found here:
www.nxjournaling.com
yes i think i remember talking to you about it
Thanks i will do some tests and post feedback
NX8.5 - NX9 User
well the code that ive posted its working a bit diferent, it processes all components (if fully loaded) and report the broken link (the part of the bronken link) and the link itself (or suposed)
broken link 1
Filename (where is broken link)
Feature(number)
Parent File (of link)
broken link 2
Feature(number)
NX8.5 - NX9 User
The code that I linked to only works on the current part. There is another version that does the entire assembly, but I'm not sure if it is posted on the site. If you combine your code and the code I linked to, you can get a version that analyzes all the parts in an assembly...
ok i will try combine and post the result, thanks.
NX8.5 - NX9 User
