I once worked on a bridge jacking problem. I recommend you use an extremely stiff beam running transverse under the bridge beams and jack that beam at several locations along its length to create a mechanism that lifts the bridge uniformly. The beam under the jacks will have to be very stiff also. In RR work, I believe they require the jacks to have 150% capacity of the lift. Probably not a bad idea. You can get some guidance about required minimum horizontal loads from the AASHTO Guide Specificaitons for Bridge Temporary Works. The minimum horizontal load in there, as well as the Division II - Construction portion of the AASHTO Standard Specifications is 2% of the vertical load. I would also use some magnitude of wind and breaking (LF) force. Oh, your bridge is straight, right?
