rockman7892
I'm looking into several options for monitoring breaker diagnostics as part of increased predictive/condition based maintenance for Substation HV breakers. Typical application is 138/230kV Substation with single HV breaker with radial feed to transformer.
In doing some research I came across dedicated breaker monitoring devices that can provide an array of breaker diagnostics from a single stand along monitoring device (INCON Optimizer 3 Breaker Monitor for example).
Looking at several of these monitors they all appear monitor key breaker diagnostics including the following:
- Breaker Timing
-Operations Count
-Trip & Close coil circuit integrity
-Charging motor current draw & run time
-Contact wear & restrike detection
-Sf6 gas monitoring
Does anyone have any experience with using this type of breaker monitor or similar device that have found it to be useful for breaker predictive based maintenance? Any recommended manufactures or models?
I also have seen applications where several of these monitoring functions can be programmed into a protective relay associated with the breaker (Breaker timing, TC monitoring, etc..)
Has anyone had similar sucess with using relay to perform monitoring for predictive maintenance vs using an external monitoring device?
- Breaker Timing
-Operations Count
-Sf6 gas monitoring
