Oct 3, 2013 #1 Weinstein Industrial Joined May 21, 2013 Messages 14 Location FR Hello, I'm trying to create a break view section of a projection view. my problem is that I can't select the chain of curves around my projection. did this problem occur often and does anybody have a solution? thank you very much in advance.
Oct 3, 2013 #2 SvenBom Mechanical Joined Jul 5, 2013 Messages 234 Location SI I guess you mean Break-Out Section View and not View Break. If so, did you create your curves in the view? If you draw curves with sketch commands, did you select Activate Sketch View first? Or did you draw your curves directly on the Sheet? Upvote 0 Downvote
Oct 4, 2013 Thread starter #3 Weinstein Industrial Joined May 21, 2013 Messages 14 Location FR Yes that's what I meant. While in drawing I used the direct sketch tool to draw the curves. I did skip the selection of the corresponding view, I did it now and it works very well. so thank you loads. Upvote 0 Downvote
