Break lines in an isometric view
jmanzi
4
I have an assembly that I'm trying to show an exploded view of. It only has 6 main parts and some screws to hold everything together but one of the components that I want to show is a very long hose that has a special attachment on the end of it. Is it possible to add break lines that only shorten the length of the hose? It seems that the normal break lines act in 2D even when I'm using them on an isometric view.
Right, Break lines will not work. But, is there another way to show that there is a break in a long part so that I can still show what is attached on the end?
You can use a Configuration.... make a Configuration of the Part\Assembly making the part shorter showing what is connected at the end and just use that Configuration in the ISO view... that would work fine... done that a thousand times showing different setups.
Scott Baugh, CSWP [pc2]
Berry Plastics
Cad Admin\Design Engineer
GEASWUG Greater Evansville Area SWUG Leader
"If it's not broke, Don't fix it!"
faq731-376
If you use both a horizontal and a vertical break line, you can break an Isometric view. I break vetically first, to fit the space, then break horizontally thru the middle of the breaks. Sylvia
