Our company brazes SA-249 stainless tubes to SA-36 structural tubing (actually A500 GrB that is qualified to SA-36 via Heat treat). We're having trouble with our latest batch of SA-249 brazing properly. The SA-36 is laser cut and the holes are dead on accurate. Tube geometry is quite good as well, so no tolerance issues.
I received MTR's on the tubes and cannot tell much difference in chemical makeup from last batch. Furnace recipe is exactly the same. Here is the chemical analysis of the last good batch:
C:0.018 Mn:1.67 P:0.032 S:0.00 Si:0.39 Cr:18.2 Ni:9.2 Mo:0.50 Cu:0.40 N:0.04 Fe:Bal. Rockwell B-71
Here's the latest that is not brazing correctly:
C:0.018 Mn:1.62 P:0.033 S:0.00 Si:0.32 Cr:18.3 Ni:9.1 Mo:0.40 Cu:0.39 N:0.04 Fe:Bal. Rockwell B-72
I would appreciate any comments/advice any of you may offer to remedy our current issue.
Thanks!
Brent
Thanks!
Brent
