Hello everyone,
I am just getting started with Journaling and am wondering if there is a file/list someplace of generic NX callouts someplace. I would like to start by creating a journal that will allow the user to select various objects (lines/arcs) and then I want to print out/use information related to those objects. Start point, end point, arc centers etc.
I started with this:
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Dim lw As ListingWindow = theSession.ListingWindow
Dim mySelectedObjects as NXObject()
lw.Open
If SelectObjects("Hey, select multiple somethings", _
mySelectedObjects) = Selection.Response.Ok Then
lw.WriteLine("You selected " & mySelectedObjects.Length & " object(s)")
lw.WriteLine("")
For Each mySelObj As NXObject in mySelectedObjects
lw.WriteLine("Object Tag: " & mySelObj.Tag)
lw.WriteLine("Object Type: " & mySelObj.GetType.ToString)
lw.WriteLine("")
Next
theSession.Information.DisplayObjectsDetails(mySelectedObjects)
End if
' The close method closes the text stream to the window,
' it does not close the window itself
' (use the .CloseWindow() method for that).
' Also, if you are using the listing window to write
' to a file, the close method will clean up and close the file.
lw.Close
End Sub
Function SelectObjects(prompt As String, _
ByRef selObj as NXObject()) As Selection.Response
Dim theUI As UI = UI.GetUI
Dim typeArray() As Selection.SelectionType = _
{Selection.SelectionType.All, _
Selection.SelectionType.Faces, _
Selection.SelectionType.Edges, _
Selection.SelectionType.Features}
Dim resp As Selection.Response = theUI.SelectionManager.SelectObjects( _
prompt, "Selection", _
Selection.SelectionScope.AnyInAssembly, _
False, typeArray, selobj)
If resp = Selection.Response.ObjectSelected Or _
resp = Selection.Response.ObjectSelectedByName Or _
resp = Selection.Response.OK Then
Return Selection.Response.Ok
Else
return Selection.Response.Cancel
End If
End Function
End Module
The problem here is that theSession.Information.DisplayObjectsDetails(mySelectedObjects) spits out everything for every object all at the same time and I want to be able to store/manipulate individual parts of that information. Am I thinking about this the wrong way or do I just need to learn what all of the callouts are?
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main
lw.Open
lw.WriteLine("")
lw.WriteLine("")
Next
End if
lw.Close
End Sub
Else
End If
End Function
End Module
