Spellbinder
I am Designing A braced Cofferdam. The inside dimension is 70.67'x20'. The long wale that i have is 70.67' long with struts at least every 19.33'. If I understand the bracing specification of AISC correctly I see that the sheet pile and cross struts brace the wale in x direction and the top and the bottom flanges are braced against lateral torsional buckling. So unbraced Length for y direction of wale is 70.67', which is affecting the capacity of the section in compression.
But i have seen calculation examples of Wales where the braced length for both x and y direction of wale is taken as the spacing between the struts.
So my question is can i take unbraced length of both x and the y direction of the wale as the max spacing between struts? If yes why?
