BP Explosion 6
Exploaion was in the resid hydrotreating unit. Everything's under control now.
Larry
We have heard all the talk about what happened to cause the leak. However, it is my understanding (correct me if I am wrong) that the area of interest here should be classified as a CLASS 1 atmosphere. If this is the case the presence of combustable vapors isn't the only problem.
We have fuel and air...where is the spark. From one of the medical respondants to the incident I have heard several injuriees stating that someone was running away yelling that his truck would not turn off (diesel). Funny how the people who heard/saw this and took off are the ones that lived.
Anyone else have any tidbits as to the ignition source?
Incidentally I know of a few refineries that have started turning diesels away at the front gate if they are not equipped with an intake shutoff valve.
Subject: CSB Investigators Continue Assessment of July 28, 2005 explosion and fire at BP Amoco’s Texas City Refinery
The following message is from the United States Chemical Safety and Hazard Investigation Board, Washington D.C.
Washington, DC, July 25, 2005 ­ Investigators from the U.S. Chemical Safety and Hazard Investigation Board today continued a preliminary investigation into the explosion and fire which occurred at the BP Amoco Texas City refinery last Thursday, July 28, 2005.
CSB Investigators Giby Joseph and Francisco Altamirano visited the site where the accident occurred for a second time. They continued interviewing plant operators, and requested additional documentation and other information from the company regarding the chemical process underway at the time of the accident. They arranged for eyewitnesses to be interviewed early in the week, and announced their intention to arrange testing protocols -- to examine a pipe that separated from a flange -- to determine what caused it to fail.
Mr. Joseph said the explosion occurred during what appeared to be a normal operation in the reactor section of the plant’s Resid Hydrotreater Unit # 1, or RHU, when an eight-inch pipe connected to a heat exchanger failed at the flange. (Flanges are pipe fittings which are used to connect equipment such as pipes and valves.)
“Recycled gas, primarily hydrogen, was suddenly released when the pipe broke away. The hydrogen, under high pressure and temperature, was ignited, sending a large jet fire shooting an estimated 75 feet westward from the flange. Damage was localized along that fire path,� Mr. Joseph said, addition that initial information indicates the hydrogen was pressurized at approximately 3,000 pounds per square inch at a temperature of over 500 degrees Fahrenheit. Heat from the fire deformed piping and bent structural beams, he added.
Investigators said the reactor combines heavy crude oil with hydrogen as part of the conversion to lighter products. There were no injuries from the incident. Investigators were told that 13 workers were in the area, including several contractors. BP has provided CSB investigators with handwritten eyewitness statements from employees, who will be interviewed this coming week by the CSB.
The incident occurred during routine operations, and not during maintenance or a startup. CSB investigators say that witnesses report having received no warning indications before the pipe failure and explosion.
Investigators Joseph and Altamirano are part of the CSB team currently investigating the explosion and fire which occurred at BP on March 23, 2005, killing 15 workers and injuring more than 170 others. After an initial assessment is made of the July 28 accident, the Board will determine the extent to which the latest accident will be further investigated, and whether it would form part of the ongoing investigation.
CSB Chairman Carolyn Merritt said, “Although this latest explosion and fire fortunately caused no injuries, such accidents are not an acceptable part of normal operations. The accident occurred at an entirely different part of the Texas City facility, but we are interested in knowing whether the two accidents share any common root causes such as lack of an effective mechanical integrity program. Such a program would make sure the equipment is safe and serviceable.�
Lead investigator Donald Holmstrom, in charge of the March 23 explosion investigation, will arrive on site Monday evening.
The CSB is an independent federal agency charged with investigating industrial chemical accidents. The agency’s board members are appointed by the president and confirmed by the Senate. CSB investigations look into all aspects of chemical accidents, including physical causes such as equipment failure as well as inadequacies in safety management systems. Typically, the investigations involve extensive witness interviews, examination of physical evidence, and chemical and forensic testing.
The Board does not issue citations or fines but does make safety recommendations to plants, industry organizations, labor groups, and regulatory agencies such as OSHA and EPA. The Board designates formal responses to its recommendations as acceptable or unacceptable, open or closed. Further information about the CSB is available from
For further information, contact Sandy Gilmour, cell 202.251.5496.
ATTN NEWS MEDIA: We do not expect to issue further information Sunday July 31, 2005.
This message was transmitted at 2:53 PM Eastern Time (U.S.A.) on July 30, 2005.
________________________________________________________
Visit us on the World Wide Web at
Larry
Pzas - Hydrogen will ignite at the source of the leak due to the static charge formed during the release. This interpretation is supported by the characterization of the fire by the CSB investigators as a "jet fire". If ignition is delayed, such as by a remote source, the event is usually characterized as a vapour cloud explosion.
HAZOP at
We should start another BP RHU thread. Pzas is talking about the March incident, which was a vapor cloud. The July incident was a jet fire of hydrogen.
Larry
owg
I was referring to the first explosion, not the latest one.
