henerythe8th
I am currently working on an analysis for a HVAC duct system in a nuclear facility. The analysis is necessary to determine what type/strength of supports are necessary in the system as well as determining the deflections at various connections to this system. The system has a temperature change of 200degF that causes "growth" in the system. It is being debated whether the boundary conditions should restrict motion in the three orthographic directions or whether the moments about these axes should be restrained as well. Can you please lend your expertise on this matter?
Also, what is the preferred method to define an expansion/isolation joint?
