Not an engineering failure but of interest to engineers.
Something fishy here when trench box is needed after the fatality.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
oldestguy said:Something fishy here when trench box is needed after the fatality.
Two workers died in Boston on Friday afternoon after a water main break flooded the trench where they were working, according to the Boston Fire Dept.
As emergency responders descended on the scene, water was removed with a large vacuum before a trench box was lowered to secure the walls to prevent the trench from collapsing, the spokesman said.
For what it's worth, it seems to me that municipalities are more likely to use trench boxes than private entities. If only because there is not as strong of a time=money influence on getting the work done.cranky108 said:FYI, government agencies are not required to follow OSHA regulations, as OSHA is federal, and many water companies are local government. Not to say the regulations are bad or in anyway harmful, but they may not apply to local government agencies.
article said:Marcy Goldstein-Gleb, the executive director of OSHA's Massachusetts coalition, told the Boston Globe the company was conducting private work, not work on behalf of the city of Boston, during the pipe break.
jayrod12 said:Essentially every utility trench that is dug here gets one since most utilities are below frost (6-8 ft)
BigInch said:I'll bet it has something to do with ignorance and inexperience.
