I also know of a 2.2 common rail turbo diesel with 130 thousand miles on board that slightly exceeds the manufacturer specifications though peak torque is a little higher than should be. Same manufacturer as mine. Bought SH, only ever treated with Mobil 1 0w40 diesel every 20 thousand odd miles.
It's not just an issue of doing without an engine overhaul. The purpose is also to continue to have no (measurable/noticeable) oil consumption and put out the factory numbers like 2.2 does.
The first pic of the cam seems to show spalling but you can't feel any irregularity in the cam surface. It's perfectly smooth throughout, at least it feels so to the touch. Tried picking at it with a tooth pick (that's what the marks in oil are) but it's mirror smooth. There's oil film on them (oil rainbow on the follower track) even after sitting for days.
I've only ever used MoS2(molybdenum disulphide), never MoDTC. Whether as a standalone additive to an LM oil without (full synth. 5w40) or mixing that oil with the one LM oil that contains moly (semisynth 10w40).
Also, another thing I liked about LM and that persuaded me to take my business to them is their classification of oil in fully synthetic, synthetic technology, part synthetic, mineral based and special, making clear distinction between their SAE group IV and III products.
About the API and ACEA certifications, you mean they could legally claim API CF, for instance, certification without the product actually having cleared AP institute testing and this would be the case if the starburst symbol is not shown? Like Amsoil claiming to "meet or exceed" API requirements in cases where the respective product has not actually been certified by API?
For example, the following engine oil
Synthoil Energy 0w40 is stated to meet API SJ/CF/SH/EC/CF, ACEA A3-98/B3-98, MB 229.1 but:
LIQUI MOLY advise this product for vehicles with the following specifications: BMW Longlife-98 ; Opel GM-LL-B025 ; MB 229.3 ; Porsche ; VW 502.00 / 505.00
They make clear distinction between between approvals/specifications/clearing and their own advisory. Why would they not do so for API and ACEA, were it not the case their products actually are certified by API.
True, there may be the issue of the approval expiry (I know Porsche approval expires) and their not being willing to renew certifications for a product that has already passed the relevant testing and is still being manufactured and sold in the same formulation and quality control. But this would be another thing. I'll check the label tomorrow for the api symbol but I don't remember seeing that on any engine oil I've come across.
Also, I have checked and Liqui Moly products have indeed cleared bmw, porsche, MB and VW certification programs. Obviously, I have not checked all their Porsche, MB, BMW, VW aproved products for such.
I'll try to save up for dyno testing (I also have to change the trailing arm bearings on the rear, the rear tires, the rear brake sabots for the drums, the front pads, the front shocks - they're leaking - and maybe the flanches as well) before and after I use the CeraTEC. They say to use it to use it every 30000 miles with at least 3000 miles until the oil change, so it has time to work in.
Cheers.
