Book on preparing drawings? 4
Lion06
4,238
I would love to get my hands on a book that deals with developing a set of drawings. I feel like I'm ahead of my peers on the technical end of the job, but only on par (possibly lagging a little) on the drawing side.
I feel like at least part of the reason is that this seems to be fairly subjective. When I work with one engineer they like to see things a certain way. If I try following that with another engineer, they'll typically want it done differently. I don't feel like I have a good handle on how it SHOULD be done.
Any suggestions would be greatly appreciated.
Milo Ketchum wrote "Handbook of Standard Structural Details for Buildings, published by Prentice-Hall. Copyright 1956, so it's old. Lots of good advice though. Examples of Small House, Small Masonry Building, Reinforced Concrete Building, Steel Frame Building, Industrial Building, and Timber Building.
I'm doing alot of drafting CADD work while getting my engineering degree. Understanding what is needed is a huge part of making a drawing set. I am lucky enought to be somewhere with a voluminous collection of previous drawings on major civil projects going back over 60 years.
The first thing I recommend is looking at drawing done with your firm and seeing what is conveyed. It is very easy to put too much information on a drawing. When that happens no information ends up getting conveyed.
Put together a drawing standards template if your firm doesn't have one already. In it you can have default samples of linestyles and font sizings and layers. This helps a ton.
The only other great advice I got from a mentor in drafting was "Say it once. Say it right. Reference it." This way you are sure you will never have internal inconsistamcies in your drawing set.
Some good advice here. I particularly agree with ash060 about consistency. Thinking hard about the set up of your drawings at the very beginning of the project not only results in a better set of drawings, but it saves a lot of time. One thing I always do is wait until the very end of the project, when I really know where everything is, to add references to other drawings.
Also, check out the following:
ACI 315 Detailing Manual (this has engineering drawings as well as shop drawings)
AISC Detailing Manual
The only ones I remember seeing are the older versions but nevertheless still applicable.
