We are using nx7.5.5.4 native, and are trying to become more efficient with the drafting portion of compound assemblies (assemblies of assemblies).
The assembly in question has multiple sub-assemblies, the BOM is set to look at all the sub-components and ignore the assembly level.
Several of the lowest level assemblies contain parts that need to be represented graphically, while being excluded from the BOM.
what is the most efficient method of excluding these components from a BOM?
We use the Master Model approach
I have adjusted my practices to avoid using reference sets where arrangements are more appropriate.
I have NOT YET figured out when to use arrangements or "component hide" to hide components, but that may prove irrelevant here.
in another thread:
The first option (component is reference) sounds perfect, but is not available to us? please advise.
in another thread:
Cubalibre00 said:(Mechanical)
24 Feb 12 5:08
with RMB on a component or sub-assembly in ANT I can set some properties.
In Assembly Tab of Component Properties command there are two options :
1) Component is reference
2) Component is Non-geometric
I didn't find descriptions in the help.
The first option exclude the component or sub-assembly from the BOM, but visible in the drafting
The second option is blanked but visible in the BOM.
