A
automaton2
Guest
I am an entry-level engineering student.
As I started learning PTC Pro Engineer 5, I ran into a problem. I asked a person with a major in drafting about this and he couldn't answer my question.
Do I need to draw threads on every bolt I am designing in Pro E? What is the easiest way to do this?
If not, than my hole for a bolt is geometrically narrower than the bolt so there is no way I can stick an unthreaded bolt in to a smooth bore without causing geometric interference glitches.
How would I solve this problem in Pro Engineer 5?
Thank you for your time.
V.T.
V.T.
